is it possible to take the engine and transmission from a mx3 v6 and put it into my 94 protege
mx3 v6 into 94 protege
yes91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Take a engine and trans from the MX-6 and stuff it in the Protege. You get more power and larger displacement ( 2.5 MX-6 vs. 1.8 MX-3 ). And they respond to turbos very well.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Originally posted by PoxIm assuming your refering to the KL-ZE, and not the DE, correct? Id love to see a KL-ZE in a 94 Protege, with a write up/how to of course. =P
But the ZE has high compression, wouldnt that be unsafe to run turbo on?2005 Mazda 3
I find it hard to believe theres enough room in the engine bay of a 94 Pro to fit that big 2.5l 200hp monster of a motor. Would there even be room at all to try and fit a turbo + - FMIC? Man, Im starting to drool a little at the thought of a KL-ZE Protege..
What do you guys think would be faster 1/4 mile? Stock BP-T or Stock KL-ZE?
Also does anyone know the weight difference on these two beasts?
Sorry for the thread jacking. =[ lol
aye, the klze and variants fit just fine. it's been done even on the 1.9 escort, there's no difference in what you need so the escort/protege regardless of what's under the hood will smile at it.
1.8 v6 from the mx is a waste IMO. higher compression is just fine for turbos, you just have to adjust and properly tune as stated. lower compression leaves room to f up.
id bet the klze stuffed bg is faster out of the box but only by a little. but consider that no one in their right mind will pop a stock klze or stock bp-t into their car, 95% of the time they have mods going in with it.Seth
2010 Mazda3 i Touring
But the ZE has high compression, wouldnt that be unsafe to run turbo on?c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Originally posted by purewhitemp5I was refering to the DE. They are more plentiful here in the states for a much cheaper price and they respond to boost better then the ZE not to mention they are basically the same engine just slightly different tweaks.
i dont see how a de would respond better to boost over a ze considering as you said, they are the same motor minus some restrictions in air flow really. What's the compression difference? i think they are almost if no identical.Seth
