problem after swap BP engine in mx-3
    ok so i finally found the source of my problem... when i turn on the key my ENGINE fuse (10A) always burn... so i thought that maybe my Main Relay is like stuck..but WHERE IS THIS FU&*(N RELAY llool if someone could give me the color of the wires that goes to this relay in a 1996 mx-3 or if u guys already had this problem maybe u could suggest me other ways to solve this problem
      if the fuse is blowing does that mean maybe you have a bad ground somewhere or a power wire accidently grounded? you might want to ask a mazda tech what color the wire is maybe they'd be willing to help
      In the Garage
      Black 93 MX-3 GS
      Bp powered
      GTR Drive Train
      The ProjectMx build thread
      MyCardomain[/SIZE]
        you could have a short, or power going where its not suppose to go
          hey buddy congrats on the swap, i am doing the same, i have a 1995MX3 RS and a 94 BP motor, more than likely you should disconnect your back up lights, its the sensor that goes from under you tranny, comes up on the right side of the motor near the bottom, its only one wire, i think it was green too, mine was covered in oil, i was having the same prob you are and now with it unplugged i dont burn the fuse and i have spark, but i think we have to swap some wires on the harness, b/c after that i still had no fuel
