I am nearing completion on my Bp and wanted to know which ECU or standalone or piggyback I should use. Right now I have the ECU/wireharness from a 91 protege but as shown bellow i just picked up the Coil pack and wireharness from a miata and i'm going to run a cam angle sensor instead of a disti
Cylinderhead:
Mild Port and polish
port match
stainless steel 1mm oversized valves
3-angle valvejob
ARP Head studs
pacesetter header (not sure if i'm going to use or not)
Electrical:
1997 Miata Cam Angler Sensor
1997 Miata Coil Packs
1997 Miata Wireharness
Making my own Groundkit
Block:
overbored
wiseco 10.0 - 10.5:1 forged pistons
B6T rods
crankshaft micropolished
rods / crankshaft / pistons / pulley balanced
Drivetrain:
Fidanza alluminum flywheel
stage 2 clutch
GTR trans and rear end
(going to have an alluminum driveshaft made)
with all of this should I just buy the Miata ECU? the Miata ECU with a piggy back? or just buy a standalone? I'm shooting for 150-170 hp right now... and in a couple of years adding another 100-200 when i do a small turbo
Cylinderhead:
port match
3-angle valvejob
ARP Head studs
Electrical:
Block:
overbored
B6T rods
Drivetrain:
stage 2 clutch
