Hi i have been having problems with my 323 GTi 1.8 bp05, my GTi has been sitting without being started for a while and when i went to start it up it wouldnt fire up,
I have checked a few thing myself with the help of the haynes manual:
Checked the that the coil has power going to it which it does,
Checked the resistance of the coil as per my manual, (it seems to be the coil from the 1.6 a per the ohms of the primary and secondary match the 1.6 rather than the 1.8, which seemed to work fine and had no problems with it being the wrong coil before now)
The spark plug leads and distributor cap were a little corroded, i have replaced the dist cap and am going to replace spark plug wires soon, but as there is no spark from the coil itself, i tested it with the help of my dad seeing if it would spark against a grounded part of the car, tried it with just a screwdriver in the hole where the coil output is and nothing either.
So im assuming that the fault lays somewhere else, im not to sure where to go from here so any input would be great.
