i sean this on ebay and it works for the 1996 so why wount it fit 1990-1994 proteges.
under drive pulley
yea, im also wondering what would have to be swapped over so we can bolt on an UDP.
JACK.-Jack
i am pretty sure the 96 escort had the bignose crank or viceversa....mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
i wonder if the 96 UD pully will fit a gtr engine... i hear they dont use v-belts either. i'll find out tomorrow :D
Originally posted by therieldeali wonder if the 96 UD pully will fit a gtr engine... i hear they dont use v-belts either. i'll find out tomorrow :D
-jon
PS: Isn't the GTR motor gonna make enough power? I mean comeon. You need to run a UD pulley to make a few more hp too?! lol**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
Originally posted by Tazman2Don't waste your time with one unless you want a possible blown up motor from the oil pump going which had happend to ALOT of miata guys who used a UD pulley!
He's just going to find out what kind of belts the BP-D uses, and is just finding any way possible to brag about having the engine.
FYI: If you have your internals balanced when installing the UDP, you shouldn't have any problems.
why not just do what im going to have done when i get the time.....
if you don't have p/s or a/c you could just have the outter belt groove machined off. then get it balanced. the issue with the oil pumps is not the lightened weight but the smaller diameter of the pulley the make sit spin to fast. ligthening some thing make sit easier to spin. changing the rotating mass is what screws with the rest of the system.
NEUMAN
i have a pulley for my 323 im going to test it on. i mean the only thing there is a the alternator so the rotating mass stays the same. thus not causign any charging issues. after thinking about this a little more the under drive pulley in noway shape or form should cause issues with the oil pump. the crank pulley has nothing to do with the oil pump. your crank is going to spin at the same ratio. its just the assecories that will change when a UDP is applied to the system. thou with the lighter stuff it will want to rev faster. just like a lightened flywheel. but not hurt anything.
NEUMANLast edited by neuspeedescort; 10-02-2006, 02:56 PM.
Originally posted by neuspeedescorti have a pulley for my 323 im going to test it on. i mean the only thing there is a the alternator so the rotating mass stays the same. thus not causign any charging issues. after thinking about this a little more the under drive pulley in noway shape or form should cause issues with the oil pump. the crank pulley has nothing to do with the oil pump. your crank is going to spin at the same ratio. its just the assecories that will change when a UDP is applied to the system. thou with the lighter stuff it will want to rev faster. just like a lightened flywheel. but not hurt anything.
NEUMAN**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
Originally posted by neuspeedescortwhy not just do what im going to have done when i get the time.....
NEUMAN
And how does lightening a rotating part NOT change it's rotation mass?
no, you don't have to cut off that part. does a pulley from a non-AC/PS car fit?
