Prt-6-005 CorkSport Complete Head Upgrade
Valve Springs: Eibach EVS, Valves: Ferrea SS Oversize, Lifters: Lightweight Racing Solid Lifters, Camshafts: CorkSport Turbo Performance Cams, Adds $425 $2549.00
Valve Springs: Stock, Valves: Stock, Lifters: None, Camshafts: None $981.00
From CS "Complete upgrade for more air flow and power! Clean and modify intake and exhaust ports, port-matched to gaskets, 3-angle valve job, new valve guides. You can also select from additional options to make the most power."
How much would it cost if you did it yourself, or a shop to do it?
