I'm thinking of converting my Pro to rear wheel drive. I know, there are a lot of problems in doing so, but a problem without a solution is called a fact. I was thinking about an 80's Camaro chassis (it's got a resembling wheelbase and a 5 litre V8 with lots of compatible tuning parts). Has anybody ever tried doing this? If so, do you have any tips?
Rear wheel drive
well since your workingwith unibody cars you cant just move stuff around like that.... could you convert to rear wheel drive with a v8 tho? yes you could but an immense amount of work is involved. if it were me i would probable get a miata rear subframe suspension and diff and go from there.... but trust me lots of work. new floorboard braceing the chassis so you dont twist the frame into a french crueller ect...mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
why not a bpt and hook up the pro 4wd rear end and unhook the front cv shafts. there you go, a powerful rwd protege91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Talking seriously, I have been doing some junk yard research on this very topic. The space between the frame rails is almost the exact same between a crown vic and a pro. So if you're serious than this is what you'll need to do: construct a cross member and bolted to the uni bodyroughly where the factory mounts are. This is a strong point in the frame. remove every bit of interior including dash. cut a hole in the fire wall and floor pan to build out for the tranny and driveline. I would locate a rear subfram from a GTX to make the job easy. have a driveline shop make a custom driveline to go from the mustang tranny to pro rear end. Than to beef up the frame, easy, build a bad ass roll cage. This has been running through my head for about 3 months, as well as a TT KLZE, longitude BP, TT13b, and the list goes on. My poor wife!
EDIT: BTW welcome to the forum!Too bad I have AWD and you don't!
if only the money pocket was bottomless91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
he still races it as far as i know. miata trans, ford 9" rear end, tube chassis...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by Flyboy87 View PostJust buy a Miata or a 240SX. Youll spend 10k plus to convert an fwd car to rwd.Seth
2010 Mazda3 i Touring
