i want to make my engine look nicer less dirty and rusty what are some suggestions...also i want to get rid of as many parts under the hood as i can i seen some pretty naked engines here and the car still runs so i wantt o know what to take off....one last thing i want to put my battery in my trunk how do i do that?? how can i pass the cables all the way back there i need more space under the hood i need to move the battery for more cone filter space heres a pic of my engine bay as it is now....im ups for any suggestions...
better looking engine then this??
Originally posted by Pox View PostOh also get rid of the Dunkin Donuts cup =[
Mean Green, Simple Green, Super Clean, etc, degreasers. I did this on my Protege and it made a HUGE difference in appearence. Of course I was at work so the Super Clean was never ending and free, so I would just spray it on then hose it off, like 5 or more times.
Originally posted by esmacmil View Post
You can take our your powersteering pump/lines/assembly and just loop the 2 lines at the steering rack together.
Yank out your a/c if you want, so that'll be the compressor/lines/ac rad. You can also take out your cruise control module/cable...umm...the charcoal canister system...relocate your battery to the trunk.
Also you can try a wire tuck. B-potent did that with his standalone...can't see a damn wire in the engine bay, looks so clean!
But that will get you a very empty engine bay. My EGT had all that stuff removed.
JACK.-Jack
Originally posted by Mazda_Powered View PostYou can take our your powersteering pump/lines/assembly and just loop the 2 lines at the steering rack together.
JACK.
For a battery relocation you SHOULD run 0 gauge wire from your engine bay through your firewall @ the engine harness seal. Then under your carpet, under your back seats. Also use a 0 gauge ground wire. Secure the battery. Make sure everything is connected properly, and voila!
JACK.-Jack
I only have pics of before i tore everything out. I only had my powersteering resevior tank and lines removed. I didn't actually yank of the pump and compressor until i replaced my engine.
JACK.-Jack
Originally posted by esmacmil View Postdude i gave you a website...come on.
its on the main page.
you're so lucky im bored.
Originally posted by Mazda_Powered View PostFor a battery relocation you SHOULD run 0 gauge wire from your engine bay through your firewall @ the engine harness seal. Then under your carpet, under your back seats. Also use a 0 gauge ground wire. Secure the battery. Make sure everything is connected properly, and voila!
JACK.
