will this oil pump fit?
    i bought an oil pump in october and finally got to the point on my engine where i needed to install the oil pump and the part that attaches to the crank is much to large of a diameter to work with my crank so i obviously got the wrong one. The company might exchange for another one but they can't find a pump for the smaller diameter crank shaft.. i finally found a part number from Hi tech and they cross refferenced with cleavite and think the above one will work.... can anyone verify this? please
    thanks for any help
    hi_tech part # is OM-141
    cleavite part # is 601-8093
    In the Garage
    Black 93 MX-3 GS
    Bp powered
    GTR Drive Train
    The ProjectMx build thread
    MyCardomain[/SIZE]
    this pump fits the 1.6L and 1.8L engines that have the small nose crank. that's years up to '91-'92 or so (?). at one point the cars popped up to a larger crank and keyway to solve reliability issues and this oil pump won't work with that crank. the small nose crank engines have a four slot pulley and the large nose crank engines have an eight slot pulley.
    BPT BF GTX Project
    Portland, OR
      8 slot? what are you talking about?
        He's referring to the Miata's crank pulleys - they had/have slots in 'em
        Original owner: 1991 Protege LX (now w/SOHC) and a few more BG's ....
          i think a crank pulley weight comarison is due for this club
            tell ryan he has to take the crank pulley off his miata and weigh it . i'll weigh a GTR one.
            -jon
              GTR/miata(big&small nose)/protege BP (big & small nose)/sohc B8(big & small nose)/B6 (big & small nose)
                we need the weight of one off a b3 engine also cause jrally used that on a bp... i might also if it is light enough
                In the Garage
                Black 93 MX-3 GS
                Bp powered
                GTR Drive Train
                MyCardomain[/SIZE]
                  so if this pump will definantly work then i am going to swap it for my current one then try and send it in to have the hole pump cryo'd
                  In the Garage
                  Black 93 MX-3 GS
                  Bp powered
                  GTR Drive Train
                  MyCardomain[/SIZE]
