mx3 b6 tranny in protege?
    I am looking at getting a 93 sohc protege and i was wondering if a mx3 1.6 sohc tranny would work in it or not. thanks
    92 mazda mx-3,escort gt engine,kia tranny,mazda 323 turbo,rx-7 vaf,spec stage 2 clutch, ,gtx ecu, fmic,cork sport downpipe,walbro 255,greddy bov,gtx injectors.
    94 blaze red mx-3 gs, all stock
    they should bolt up pretty straight-forward AFAIK.
      should work fine, but you will need the flywheel and clutch from the mx3 i believe.
      -jon
        What Jon said. You have to have the matching flywheel/clutch for the transmission you're using. I believe all the mounts are the same aswell. Not sure about the axles, since it is an F-Series tranny i would suspect they're the same.
        JACK.
