After installing the fresh head there was lifter noise. So i figured since i was gonna inspect them I'd install the exhaust cam on the intake side. Well after everything was timed and ready to go, i started the car and there was an instant pop from the exhaust and now it doesn't crank, just makes a weird noise when i try to start it. Anyone know what i should check/adjust or what i could have broken. Could i have over tightened something, or could the distributer timing be off, I'm sure the cams are properly timed...what i did:
For the exhaust side set the tab on the end of the cam in the E slot and was facing up on the mark, the intake side was the exhaust cam with tab in the I slot, and the tooth facing up is the one 180 degrees across and three teeth to the left, and the crank mark was on the second from the right when facing the drivers side spot.
< I misused this smiley, please excuse it, didnt understand the expressions
