Yeah it's in an Escort but I can't seem to figure out what is going on. Still stock boost.
Engine used to Rev up and down at the light. Changed the IAT from the escort and still had the same problem. If I block off the VAC line from the IAT it will Idle 800 all day long as long as there is no load for the stepper motor. I got so annoyed with it I turned down the idle with the screw on the TB. Runs like crap at an idle but it doesn't rev...
That is problem 1, problem 2 is when I get any kind of boost engine cuts out and spits and sputters especially at WOT. I wired in the 4 wire TPS. before all of this during the swap on my NA harness along with everything else needed (knock control, resistor box etc).
I think that it is the TPS although I have heard that it can be my plug gap and I have tried a different gaps 40,30,25 (really spits at me then). Engine will not rev over 6K at an idle.
Ok if you don't think that it is the TPS how do I check the VAF to make sure that it is functioning correctly? (GTR VAF)
I need a specific model of plug and what gap you think would be sufficient.
Is the base timing for the GTR still supposed to be 10 deg?
I have the GTR ECU also and all the wires I believe are that as they would have been on the GTR harness.
FPR seems to work also... I plugged it and drive my can and flooded the hell out of it. LOL probebly shouldn't have done that.
This problem has really been killing me, I can drive it around town as long as I keep it under 3500, after that it just sucks.
PLEASE HELP
-Steve
