Looking to see if short throw shifter is availiable for my car. 1991 mazda 323. Ive seen them for 92 and up but not older. What is the difference???
1991 323 shifter
no difference for the shifters 90-94. 91+ escorts will work, mx-3s, ect.
JACK.-Jack
you need to then tack weld the ball in place after and grind the welds down smooth.. otherwise it could possibly move around as youve melted the original glue away with the heat. i've made two of these, one is in my car right now (works great).Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yea, tack welding it in place isn't a bad idea, but i don't think it's neccesary. when i made mine, at first i pushed the ball too far up, so the bottom of my shifter barely hit the exhaust, so i had to move it back down a little bit. when i put it back in the vice it did not want to move AT ALL even when i was hitting it with a hammer in the vice, until it was just as hot as the first time. it takes a few minutes to heat it up with a heat gunsigpic
i used a propane torch, so maybe i damaged the glue a little more than you did LOLEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
