I installed my Autometer oil pressure gauge and got the sender hooked up on Thursday... I ran it around town (probably 5-7 minutes) and then parked it for the night. I went to the dragway Friday and on the way up, passed a string of 5 cars heading out of town.
As I was hitting the last car, I saw my check engine light pop on. It's never come on before this. (Installed A/F ratio gauge and hooked that up too, but I can't imagine that'd throw it off by adding that into the mix).
Anyways - When I installed the Autometer gauge, I took out the stock sender, put the Autometer in and then ran a new wire to hookup. I left the stock wire "hanging" but out of the way.
I have a feeling I need to do something with it, but I'm not sure what. Any suggestions?
Car Specs - Festiva with BP swapped in... Running on the Festiva harness with the BP plugs splices where necessary - runs fine and gets up and moves fine - again, never tossed a code before, and I didn't actually check for codes (mostly because I'm not sure how)...
