![bash](https://www.clubprotege.com/forum/core/images/smilies/bash.gif)
Omg !!!
Omg !!!
does anyone have any pointer in getting the center bolt out that holds the harmonic ballencer and the pulley boss on the crank shaft. I've been struggling with this for about an hour and it just won't break loose.
94 protege lx 5-speed (elegent beige) SOLD
http://www.cardomain.com/ride/2848779
99 626 lx-v6 5-speed (driftwood) Runs great and sounds awesome
http://www.cardomain.com/ride/2344240Tags: None
When I replaced my crank pulley with an underdrive pulley I had to put a breaker bar on it and brace it on the engine then tweak the starter. Worked great.Block is almost done, cylinders are overboard for Weisco pistons, pro gram billet main caps have been line bored, and my chinese EDT rods have been machined to right specs. Everything has been balanced.
just make sure you unplug your coil before you do this, so the engine doesnt accidentally start!Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Unfortunately this has already come to mind and had no success. I have also taken off the inspection shild on the tranny and jammed a screw driver in the teeth on the fly wheel adn that didn't work either.94 protege lx 5-speed (elegent beige) SOLD
It should work unless your doing it wrong. Jon recommended this and it worked after struggling with it for hours! I used a semi breaker bar against the control arm on the top and made sure it was nice and tight so when the start kicked in it wouldn't break something!**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods!**SOLD**
i am more than positive that i was doing this right but anyway i'm bringing home the big gun from my tool box at the garage and i'll break that sob loose.
so i'll update on thurs see yall.94 protege lx 5-speed (elegent beige) SOLD
MasterBanter yes, the breaker bar just rests against the control arm and the torque from the starter should break it loose as long as you have a good battery. Which I did not and now it's dead.94 protege lx 5-speed (elegent beige) SOLD
ya I have the optima sitting on the shelf at work and I'll pick it up as soon as I get a timing belt in the car and hear it purr for the first time.
Can't wait.94 protege lx 5-speed (elegent beige) SOLD
So its thurs and yesterday I charged my battery for 9 hoirs on the slow charger. At 530 its back to the car to finish breaking that f'n bolt loose.94 protege lx 5-speed (elegent beige) SOLD
