to my rally drivetrain puzzle. 2nd Gen upper intake manifold fitted with a full 60mm TB off of a 2.2L Subi, special manifold rework internally and lastly machined MSP diff carrier for the speedo gear, hope I got the gear on in the right direction, made the most sense.
The idle air control will be built with a custom remote location, off the TB, allowing air into the brass fitting on the bottom. The TPS doesn't just bolt on, but it was fairly straight forward to make an adapter plate. The Subi TB shaft is built the same way as the Mazda, the cable pull ring even bolted right on.
-Jon R.
-Jon R.
