What causes my shifter to have alot of slop in it. I replaced the shifter rod bushings ( the ones that are in the knuckel right before the trannie) and they helped a little, but it still has alot of slop.
Loose Shifter
try replacing the other bushings? theres the ones in the shifter and also the shifter support rod bushingEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yes its at the bottom pivot point where the shifter connects to the shift rod. energy suspension sells a polyurethane support rod bushing thats probably as cheap or cheaper than an OEM one. suspension.com has it under the escort ZX2Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Also look in the for sale section under group buys. 1 of our local people sells good quality bushing for the whole assembly. Maz1.8t I believe is his screen name. Send him a pm and se if he has some. I need a set myself soon.1993 Protege LX-Midnight's shadow SOLD
Originally posted by therieldeal View Postenergy suspension sells a polyurethane support rod bushing thats probably as cheap or cheaper than an OEM one. suspension.com has it under the escort ZX2
Clint1994 Mazda Protege DX (261Kmiles): Eibach springs, Tokico struts, Addco sway bars, massively ghetto-fabulous OBX camber bolts set to max. -ve, Energy Suspension LCA bushings, disc brake conversion, Carbotech XP8 (front) and AX6 (rear) pads, ATE Superblue, 15x7 Kazera KZ-M w/ 205/50/15 Avon Tech Ra (track), 15x6 Miata wheels w/ 195/50/15 Hankook Ventus R-S2 (street) and 14" stock wheels w/ Blizzak WS-60 (ice racing), A/C delete, BP swap, POS Pacesetter (w/ leak), 2.25" custom exhaust, cage and full SCCA ITA prep possibly in the works...
1995 3000GT VR-4:Tein Flex, 332mm Stoptechs, manual steering conversion, custom brake lines with cockpit-mounted prop. valve, AWS delete, DSM sidemounts, full ATR single-exit, 13g/9b mismatch w/9psi WG springs, DN o2 housings, SAFC, AEM wideband, much more, etc.
1987 BMW 325is:Bilsteins/H&R Springs, very solid motor mounts, 220k - stodgy daily driver
Originally posted by therieldeal View Postyes its at the bottom pivot point where the shifter connects to the shift rod. energy suspension sells a polyurethane support rod bushing thats probably as cheap or cheaper than an OEM one. suspension.com has it under the escort ZX2
Hey man, I went to that site and was unable to find the parts that I was looking for. I was after the shifter rod support bushing and it was only avail. for the 97-01. I think that I have read that its compatable but I'm not sure. Someone help me out
Originally posted by Turpro View PostAlso look in the for sale section under group buys. 1 of our local people sells good quality bushing for the whole assembly. Maz1.8t I believe is his screen name. Send him a pm and se if he has some. I need a set myself soon.
found the link http://www.wihandyman.com/forum/showthread.php?t=24152
