Hey I came across this today, so if you havent already seen it, here it is...
90-94 MAZDA PROTEGE LX 1.8L DOHC UPGRADE TURBO KIT
Starting bid: US $988.99
Your maximum bid: US $
Place Bid >
(Enter US $988.99 or more)
price: US $999.99 Buy It Now >
End time: Nov-03-07 16:07:22 PDT (5 days 23 hours)
Shipping costs: US $87.99
Standard Flat Rate Shipping Service
Service to United States
(more services)
Ships to: Worldwide
Item location: El Monte, California, United States
History: 0 bids
You can also: You are watching this item in My eBay (2 items)
Bid with Bid Assistant
Get mobile or IM alerts | Email to a friend
Listing and payment details: HideShow
Kit includes:
-JDM Turbo Custom Piping Kit
7x Pieces of piping for turbo and intercooler setup. (Piping includes SSQV blow off valve adapter)
Light weight aluminum design. Adjustment are needed depends on engine layout and different setups.
6x Sealing couplers & x12 T-bolt clamps: 2.75 inch diameter couplers (color maybe vary) with flexible steel T-bolt clamps for better and stronger holdings to prevent leaking.
-JDM Turbo Intercooler
1x JDM Intercooler: tube and fin design, 28x7.5x2.5 inch cord size.
2.5inch in/outlet diameter, handles up to 30psi/500hp.
-T25/T28 Turbocharger
1x Internally wastegated turbine housing.
Great size for applications w/ packaging constraints
Ideal for smaller displacement engines making up to 270 hp.
Has a T25 turbine inlet flange.
-Stainless Steel Mid Pipe
1x Stainless Steel turbo Mid Pipe:70mm Turbine Outlet Elbow for T25/T28 Turbo.
It reduces turbo lag with noticeable improvements throughout the power band.
Boost will be attained at a lower RPM.
Made from SUS-304 Stainless Steel.
Direct bolt-on application
Requires modifications to fit your downpipe.
-Stainless Steel Manifold
1x Stainless steel turbo manifold: Higher Resistance to Heat, Made to fit BP-ZE Engines, Bolt on Manifold.
Fits with t3/t4 hybrid turbo and 35mm/38mm wastegates.
Fits only on 1.8L DOHC Engines.
Professional Installation Highly Recommended.
-JDM Blow off Valve
1x JDM SSQV Blow off valve w/ bov adapter: Quick response with high capacity Up To 1200HP or 25 PSI of Boost Pressure.
Professional Installation Suggested.
Aggressive blow off sound comes with bolt flange and hardware.
Adapter piping can be bolt on or weld on, easy installation.
Most parts are bolt on but some items may require modifications. All items color may vary, please check with us for availability . Professional installation is high recommenced. Instructions are not included.
Place Bid >
(more services)
Ships to: Worldwide
History: 0 bids
Kit includes:
-JDM Blow off Valve
