Is Bp T Compatible With Enthanol?
Ethanol
in stock form you mean?
or with 80/20. 90/10 mix from pumps?
In NZ we have 90/10 mix now but our fuel pumps, regulators are NOT happy using the mix
Engine should be fine, but eveything elsethat sits on the motor my not be
you also need to buy HUGE injectors as etha is very dry and you need heaps to get the same A/R
Originally posted by protégébob View Postas long as there is no rubber anywhere in the fuel system you should be fine. and like dave was saying ethanol does burn faster then straight fuel so you might have to retard your timing even more then normal.
Originally posted by jumpncrash View Postwell if ur looking to be eco friendly maybe ethanol isn't the solution. It takes a litre of diesel to make a litre of ethanol, the tractors and other farm machinery that are used to harvest corn don't run on ethanol.
