After my second B8 to BP swap, I figured this might be useful to someone. I'll update it as I remember things I came across, or as I come across other things.
Keep in mind that my engine and its accompanying accessories came from a Tracer, so they might be slightly different. I also did not swap the axles or tranny (yet).
- Rear radiator hose (block to heater core) is different. The B8's outlet is on the disty side of the engine and wraps around the back. The BP's outlet is in the back, next to the oil filter
- The fuel lines to from and to the fuel rail are different. The B8's are both on the disty side of the engine. The BP's filter to rail line is on the Disty side, the rail outlet (after the pressure regulator) is on the belt side and wraps around the back. NOTE: I had to buy ~2 feet of fuel injector line to complete this connection.
- The Escort/Tracer main harness gromet is larger than the protege (and probably 323) harness gromet. this means you'll either have to swap the harnesses or rig the tracer/escort harness if you don't get the "mazda" one.
- There seems to be more/different vacuum lines required for the BP, as well as more vacuum line connections on the intake manifold.
- The A/C Compressor line connectors are slightly different for the tracer/escort.
- The power steering pump might be slightly different for the tracer/escort. I haven't played around with it enough to see if it will work with my old DX stuff yet, since I think I'm just going AC and PS delete.
- I had to reuse my B8 radiator connectors, but I think this is only because the tracer/escort radiator is different from mine. Can someone confirm?
