I have searched the megasquirt forums and the local forum and I can not find this answer anywhere. I am trying to find out what the function of a PWM valve is and if there is a PWM valve on my 91 LX.? Can any body help me with this?
PWM Valve? Mega squirt?
sigpicGet Gnarly
But with the throttle screwed on, there is only the barest margin, and no room at all for mistakes. It has to be done right... and that's when the strange music starts, when you stretch your luck so far that fear becomes exhilaration and vibrates along your arms. You can barely see at a hundred; the tears blow back so fast that they vaporize before they get to your ears. The only sounds are the wind and a dull roar floating back from the mufflers. You watch the white line and try to lean with it... howling through a turn to the right, then to the left, and down the long hill to Pacifica... letting off now, watching for cops, but only until the next dark stretch and another few seconds on the edge... The Edge... There is no honest way to explain it because the only people who really know where it is are the ones who have gone over. The others- the living- are those who pushed their luck as far as they felt they could handle it, and then pulled back, or slowed down, or did whatever they had to when it came time to choose between Now and Later. But the edge is still Out there. Or maybe it's In. The association of motorcycles with LSD is no accident of publicity. They are both a means to an end, to the place of definitions.Tags: None
Originally posted by Lex View PostPWM stands for pulse width modulation. The idle air control valve is a PWM valve.sigpicGet Gnarly
