Please tell me what I may be missing. I started with a complete motor.
Rods
Pistons
Rings
Water Pump
Oil Pan Gasket
Oil Squirters
Crank Scraper
Crank Pulley Bolt
MBSP
Main blocks
Main studs
Oil Filter sandwich adapter
Intake manifold
Intake manifold bolts
Exhaust manifold
Exhaust flange
turbo
turbo flange
Turbo Header
turbo oil feed
head
camshafts
cam gears
timing belt
timing belt adjuster
timing belt idler
acces belt
throttle body
throttle body gasket
exhaust gasket
intake gasket
head gasket
fuel rail
fuel rail fitting
Injectors
MOTOR MOUNTS
a.
b.
c.
d.
valves
springs
valve seats
oil pump
flywheel bolts
head studs
flywheel
clutch
half shafts
gasket set
PS pump
HO alternator
A/C compressor
PS lines
Coil
Ignition
Plug Wires
Spark Plugs
Rods
Pistons
Rings
Water Pump
Oil Pan Gasket
Oil Squirters
Crank Scraper
Crank Pulley Bolt
MBSP
Main blocks
Main studs
Intake manifold
Exhaust manifold
Exhaust flange
turbo
turbo flange
Turbo Header
turbo oil feed
head
camshafts
cam gears
timing belt
timing belt idler
acces belt
throttle body
exhaust gasket
intake gasket
head gasket
fuel rail
fuel rail fitting
Injectors
MOTOR MOUNTS
a.
b.
c.
d.
valves
springs
valve seats
oil pump
flywheel bolts
head studs
flywheel
clutch
half shafts
gasket set
PS pump
HO alternator
A/C compressor
PS lines
Coil
Ignition
Plug Wires
Spark Plugs
