sorry, everyone, this has been covered, but the more I read the more confused I got.
I have a 92 LX with na BP and mtx. its a 3-wire switch-type TPS.
I want to install a WB o2 controller that can also datalog (see link below). It would be helpful to be able to datalog throttle plate angle, but this requires TPS with linear potentiometer, like the 4-wire atx TPS.
I can handle the wiring part (the output of the linear potentiometer won't go to the ecu, it'll go to the WB o2 controller for datalogging). What I don't know is whether the atx TPS is a direct swap to a mtx throttle body. Seems I have read that its not because one has a D-shaped throttle plate shaft and the other does not. Is this true? What about swapping the whole atx throttle body with 4-wire TPS for the existing mtx throttle body?
Seems I have also read that the GTX (BPT) also has a 4-wire TPS, but I don't know if that's a direct swap either, and where I could get one if it would fit.
The WB o2 I'm going to try is the JAW (its a DIY assembly)
Thanks in advence for your time.
