anyone running this set-up? I have the street modified act clutch, with the heavy duty pressure plate, however I think the clutch is only good for about 270ft/lbs or so, and the spec clutch is more, was thinking bout trying a spec stage 3+ clutch with the act pressure plate if its doable, I just dont want to get the trans together and have to pull it again cause the flippin clutch is slipping you know......
spec clutch, with act pressure plate
whatever Ryan, bpt323, is running, doesn't have a crappy hard engagement, and has held up well to all he's put at it. its a spec stage 2+ I believe, but I can't remember. a short search should find that answer.
I've heard better things about spec than act on this board, that's who I'd trust my torque to.No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
Originally posted by Lex View PostI think Ryan has a stage 3+ the full faced disc one.
Originally posted by bpt323I run a Spec stage 3+ full faced carbon ceramic, designed to hold low-mid 400's in ft.lbs It works great i've no issues with it what so everNo car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
Originally posted by swalltr207jg View Postwas thinking bout trying a spec stage 3+ clutch with the act pressure plate if its doableEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i dont think its ever been done...
but i dont see why it wouldnt work.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
The less clutch surface area the disk has, the more grip you'll get out of the pressure plate. But, you may get a slightly increased hard engagement, hard to slip. I'm not sure how that disk looks. When I ran a four puck disk on the last rally car, once it got up to temp, it was a bitch to try and get the clutch to slip, it just wanted to grab and go.
-Jon R.
the spec stage 3+ is a carbon/metallic material (usually used for puck discs) but its a full faced disc for smoother engagement.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
what sort of friction material is that again alex?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
