anyways thought F'it i'll take the car to get tuned now so i can see what sorta differance the ITBs will "Actually" make
here is the engine as is after the budget rebuild
![](http://img443.imageshack.us/img443/6091/04032008045mediumfo5.jpg)
so about 102-3wkw, (138WHP for you US ppls) loving the flat torque line..explain why it feels so "slow" no changes in its power band
Specs are
"block"
9.8:1 OEM Astina GT pistons
ACL bearings, but stock rings (re-used even)
stock conrods but shot-peend
BP02 crank, balanced/polished
stock pullys, harmi balancer etc (could have made some new ones and got more HP)
"Head"
polished BA japspec head, tiny porting, removed castings
KJ2 BP valves
Jap spec exhaust cam - BP06
Astina GT ExhINT cam using BP05 exhaust cam (Astina GT) using a DIY camgear mod to suit
Stock Astina GT inlet manifold, BP26 T/B (its has 4wires so i used it)
"Ehaust"
Stock OEM 4-1 Cast POS!, polished internally and enlarged flange from 1.7" to 2"
Mazdaspeed 2" exhaust system taken from a BA lantis type r, diy'd to fit, and a cheap o nasty muffler thats 2.5" in and out ..1 res and 1 muff
"misc"
Link G3 LEM, Mitsi Vr4 wasted spark setup
Toyota Ae111 Blacktop 4age-20V ITBs with exhaust upgrade made 96wkw (same dyno) and these are ment to be 125KW at flywheel
so im guessing a easy 134KW in my car now .the Astina when i first did the GTX conversion on its first run made 105wkw, on the same dyno , and my car feels almost the same
Specs are
"block"
"Head"
KJ2 BP valves
"Ehaust"
"misc"
![Stick Out Tongue](https://www.clubprotege.com/forum/core/images/smilies/tongue.gif)
