I have a couple questions about the fuel system on the 4wd. I understand there there are 2 pumps,One to feed the engine and one to transfer fuel to the other side cause the tank is divided into two cause of the driveshaft.
Im installing a walbro 255 fuel pump and was curious if I need to install a larger transfer pump. And my other question is how often does this transfer pump run?
And is there a sensor/float to determine when it runs. Cause I also changed the chassis harness from a 4wd to the LX protege so I can have power windows and mirrors and all other LX accesories, and I want to make sure the 4wd fuel system will operate properly.
