knock sensor
    knock sensor
    is it neccessary for a bpt?
    nope, it will run with a degree of timing off.
      well thats not really good is it
        It's not nessesary but helps if theres something wrong with your car. It can make adjustments too keep you semi-safe.
          Unless you are leaving a bpt stock and using good gas or are having a real good tune done I wouldn't be without one.
            it only pulls 1 degree of timing ... back then knock sensors weren't as accurate as modern ones. Without it, it will run in derated state all the time.
