hay i'm new, i would like to ask how to pull the speedometer gear out so i can add fluid. i have the cable out and the 10mm out but it will not move. is there a clip or somthing i didn't do? or whats the deal here?
transmission oil change
these things can get REALLY stuck especially if they use salt to treat the roads in the winter in your area. they do here... and i once came across a speedo sender that i could NOT get out, no matter what i did. luckily for you the protege ones are more durable than the escort ones... and therefore easier to remove lol. try and get it to spin, thats your best bet.
when you put it back in, lube that thing up really well with grease, anti seize, or even just gear oil.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
just fill the trans from the oil level hole. Its easier but takes longer.Beater=/= Sleeper
the gear oil level hole is the bolt in front of the trans thats there for the purpose of checking the fluid level. You're not suposed to fill it from there. But its a hell of alot easier. Just use a hose jamed in it and put the gear oil in that way.Beater=/= Sleeper
its not the one with wires.Beater=/= Sleeper
No problem.
Make sure your cars on a completly flat surface and check the fluid level a few days after you fill it up just to be sure.Beater=/= Sleeper
