does the unduerdrive pulley of a bp fit on a bpt..someone tell me taht don't fit
bpt pulleys
someone told you wrong then cause its the same block and head only big diff is intake and exhaustCheck out the Pics
http://www.wihandyman.com/forum/vbpi...?do=view&g=228
Mazda's Rule Honda's Drool
There are two different types of pulley though. Be sure to use the right one. One has a multi ribbed groove for the AC/PS and a v-belt groove for the alternator/water pump. The other pulley has multi-ribbed grooves for the AC/PS and the alternator/water pump. Both will bolt to the engine though, yes.Tyler has spoken
Originally posted by theredrocket View PostThere are two different types of pulley though. Be sure to use the right one. One has a multi ribbed groove for the AC/PS and a v-belt groove for the alternator/water pump. The other pulley has multi-ribbed grooves for the AC/PS and the alternator/water pump. Both will bolt to the engine though, yes.
The Beast : sleeper 323 93 25th
The Apprentice : Mazda 3 skyactiv 2012
Also, don't forget that there's 2 different size cranks. Small nose=22mm and big nose=27mm.1993 Protege LX-Midnight's shadow SOLD
Originally posted by luckycharms View Postbut does the bp and the bpt can have the same crank?1993 Protege LX-Midnight's shadow SOLD
There was a year break, where 90-92 (or something) had the small nose crank, and then 93-94 had the large nose crank. As Chris said, you will need to take the pulley off of your BP and just quickly measure the crank to see if you got a big nose or small nose crank.Create your own VB Gallery here.
yes.
they seem to mostly be long-nose style actually (not to be confused with big nose)... not the original small/short nose.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postyes.
they seem to mostly be long-nose style actually (not to be confused with big nose)... not the original small/short nose.sigpic
