i searched and couldnt find it. all you guys that have a cone filter on your cars, how do you bolt down the VAF so it isnt bouncing around?
how do u bolt it down?
Kevin
personally i had a bracket custom made and bent to bolt down to a 12 mm bolt located just below where the stock air box was mounted.. most people just wedge the damn thing in there, but an angle grinder, drill press, and a few extra pieces of scrap alumninum or steel, you'll be set to go. don't get me wrong, it's not rock solid.. it does have some play, but it's got enough strength to keep the intake from breaking apart on a rough road or a tight corner.
peace
never bolted it down....it never rattles or ****s up, so there is no point IMO93' Noble Green MX-ZE (sold )
02' Graphite Grey WRX Stage 4, 286whp
05' Pontiac Vibe daily driver, lowered/tinted/rims
Kevin
likewise, i just think that many throw the thing in there, have some intention to mount it at a later date, and never find the need to. for me, it's just a peace of mind.. i've had to replace this sucker once, i didn't want a reason to replace it twice.
peace
Originally posted by Semtex
can you explain this one to me, why would it need to be loose for engine torque???James G.
sobe83@yahoo.com
AIM: DVS 323BPT
MySpace
Cardomain
<BR>
<marquee>Turbonetics T3/T4, RC 550cc injectors, Walbro fuel pump, SSAutochrome Miata manifold, Tial 35mm wastegate, large FMIC, Apex-I SAFC, GReddy Type S BOV, 2.5" aluminum charge pipes, NGK plugs/wires, RX-7 VAM, 3" turbo-back exhaust, ARP head studs, H&R Springs, S/R struts, Sony XPlod deck-2/12" subs, Power Acoustic 800w amp, Pioneer speakers, Evo front bumper, ADR DV8 17" wheels.</marquee>
Made a bracket out of angle iron. It was pretty easy. It's like Darryl's.My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
The OEM airbox is bolted down and the VAF is bolted to that, it's the accordian intake tube that accounts for engine torque. If you have an aftermarket or custom intake tube, then the silicone adapters should take up some of that torque, enough to not create a stress point and cause a leak...won't happen if the clamps are good and tight.
But i'm with demoninvictus in that fact it's peace of mind to have it bolted down, as well as being a little presentable than a dangling intake and VAF....but hey, if you don't care, neither do i
you can bolt it down, but theres a big difference bolting down an after market aluminum intake over a flexible stock intake. i wouldnt bolt down my vaf, i'd prolly crack my cheap plastic intake tube off my turbo.James G.
sobe83@yahoo.com
AIM: DVS 323BPT
MySpace
Cardomain
<BR>
