whats the CEL code 3long, and 4short mean please thanks
i recently put it back together, and i'm getting 3long flashes, and than 4shorter ones after a pause, please which ones that means, or where the list is for them, thank you, tty guys later.
Idle Speed Control. Has a 2-prong connector right under the throttle body. The FSM states that the resistance between the pins on the valve should be 11-13Ω at 68°F.
The FSM says the colors are Blue/Orange and White/Red. The White/Red should have 12V since it gets power through the fuel injection relay. The Blue/Orange goes to the ECU. If you thought they were grounds, what did you connect to the actual ISC Valve (it's the only electrical connector on the throttle body)?
Wow... how the fcuk did you miss the sticky thread right at the top?
Member of MX-3.com
