Okay, I just took my car for a pre-Autox alignment to add some negative camber. I have ZX2 S/R struts and h&r springs.
He initially set it to -1.75* and found there was a nasty vibration. He said my right-side axle "pillow?" was pushing up against something and set it to -1*. I test drove it (harder) and there is still nasty vibration, especially when turning right under any amount of load.
He said there is some play in and out, but it is really tight, and is pushing up against some stuff (?). i wish I knew the terminology better. He said i should undo some bolts and try elogating some slots for more travel in and out?
Could I have the wrong axles? When i swapped to the BP, I got axles from a different lot (a non-self-service one) and asked for axles from a '93-ish Escort GT, as noone had Protege 1.8 dohc ones.
If I have been given the wrong axles, would they even fit onto the car if they were from a 1.9l escort, or a 1.8l sohc protege?
Please help! AutoX in 2 days and a nasty-driving car right now![Frown](https://www.clubprotege.com/forum/core/images/smilies/frown.gif)
I'm trying to find axles lengths of the various models of Protege's and Escorts to see if I'm even on the right track, but no luck so far.
