Hey i know this might sound a little noobish but i might buy already welded up 3inch exhaust piping from a member over here but i have a 2.5 inch inlet muffler can i just weld a peice of piping in between the two so that it would allow me to weld the muffler to the exhaust ? and also how much of a powerband loss am i looking to see if i run 3inch piping on a stock na setup for a little while as i gather parts for my turbosetup. its not like im going to keep it na so i just want to know for the heck of it because i might drive it around for a little bit once i drop my new bp in there and there is no exhaust piping on the car as of now so id have to put the 3inch piping on or run open downpipe lol but thats a little too loud
3inch exhaust to a 2.5 inch muffler
a bit of flaring & you can mate the two together---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
You actually want a little back pressure when you are N/A, otherwise it's gonna affect your low end torque... off the line performance will suffer. So puting that 2.5" muffler back will help you a little while on N/A. When you go turbo you better put a 3" exhaust on there... turbo's do not like back pressure. They actually say that an open to atmosphere right after the turbo is the best bet, but no one wants that.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
Originally posted by Shades View PostYou actually want a little back pressure when you are N/A, otherwise it's gonna affect your low end torque... off the line performance will suffer. So puting that 2.5" muffler back will help you a little while on N/A. When you go turbo you better put a 3" exhaust on there... turbo's do not like back pressure. They actually say that an open to atmosphere right after the turbo is the best bet, but no one wants that.
here ill send u the link http://www.wihandyman.com/forum/showthread.php?t=42217
its that, cant i just weld that up to my stock dp or something for now then once i go turbo ill just get some sort of custom downpipe for that.
Originally posted by deathtrigga View Postright but i have 3 inch piping that im planning on running witha 2.5 muffler and i want to just have it setup NA then just use the same setup for my turbo should be fine right?
Member of MX-3.com
What do you mean by fine?... yes it will run. But you're probably robbing some performance after you go turbo.
Originally posted by deathtrigga View Posthere ill send u the link http://www.wihandyman.com/forum/showthread.php?t=42217
its that, cant i just weld that up to my stock dp or something for now then once i go turbo ill just get some sort of custom downpipe for that.Cincinnati, ohio Bengals for life
"Who Dey"
