Hey guys i have been looking for solid lifters for the bp05 head. Any suggestions would be great, but the more stronger or expensive the better cause i switched to some pretty crazy cams and springs and my revs will hit about 10,000. Head originally from 95 escort gt
solid lifter options?
miata lifters are solid not sure what yearssigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
come to mazdasnw.com if you live in the northwest
What cams did you get? What head work did you do?
--FerdiIf you can't differentiate between brake and break, you should go back to school
I don't think the 505's are that extreme. Jon (therieldeal) runs them. Atleast you should start with the BP4W head from a Miata. It already has the solid lifters and flows better.
Why do you want to rev to 10k? You'll never make power up there, imho.
Also, if you are serious about 10k rpm, you would want to switch to shim-under-bucket or you'll be throwing the shims. Plus, it lightens up the valvetrain.
--FerdiLast edited by ftjandra; 11-21-2009, 02:30 AM.If you can't differentiate between brake and break, you should go back to school
Miatas came stock with solid lifters in 1999"See that car, in the 80's that car was deadly." Random man to his son while passing the GTX in a parking lot
Originally posted by neuspeedescortthe proper spelling would be "Launchabilitiness" i do believe.
-88' Mazda 323 GTX, caged and ready for dirt
-93' Mazda Miata, half caged
-09' Mercedes C63 AMG
-87' Toyota Land Cruiser, 33's with slight lift, safari style!
yeah the 505's are a mild performance cam, certainly not good to 10K LOL
actually the 99/00 solid lifter miata cams have damn near the same amount of lift, but they arent the right profile for HLA's. if you wanted solid lifters you should have bought solid lifter cams...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
the cams i have are recomended to use with solid lifters. my previous cams were for hydraulic. my cam and spring combo are good to 10,500rpm. i want to rev at 10k because once you are past about 7,500 your not making power, your gaining in mph untill the diff is run outLast edited by 88gtbp-t; 11-21-2009, 11:50 AM.
IMO there is still no reason to rev a BP to 10k... they dont have a very good rod ratio, your piston speed will be through the roof. i hope you have forged pistons and rods...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
You can convert to solid lifters by using your cam follower from your factory HLA and 'locking' the HLA part with solid rod, you then shim to suit and hey presto! Solid lifters. Its time consuming, however effective, takes the same time to do as solid miata cams would take as you still have to take the cam out.
Performance shims in AUS make the lock bars, and can provide you with shim material, always leave a tad more clearance on the exhuast side.
If you have access to a solid NB8 miata head, id use that.
Im currently doing some research because i think RB26 solid lifters are the same diameter folllower (the part the cam touches) as the BP
Cheers
Josh
10,000???? You are crazy to go that high! When it blows up, post pics of damage!My family has lots of bg's!
2003 Ford Escort ZX2: Project car/future daily driver. Built Ford Tough (With Mazda Stuff)
1999 Escort ZX2: Daily driver/beater. Going to be replaced by the '03 next summer.
2000 Escort ZX2 S/R: bought wrecked, going to use as parts car
1992 Protege LX: My old race car. Just a wrecked shell right now. Waiting for scrap to go up so that I can get rid of it.
1992 Mazda 323: Race car
1992 Escort Gt: My grandpa's old race car
1994 Escort GT: My grandpa's new race car.
Parts cars; 1993 Escort Gt, 1995 Escort lx
I can't remember the name of the Japanese company that makes those solid lifter kits... Muruhara or something like that, they have those kits where it puts the shim under the bucket so that it will not fly out like the Mazda Miata style where the shims are on top, which apparently when rev'd up too high will have a chance of flying out.
... and BOOM!
Oh found it... Maruha!Last edited by Shades; 11-29-2009, 12:17 PM.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
