bored throttle body
    bored throttle body
    i have a spare throttle body and intake manifold and i have friends in machining classes. i was thinking of giving them to my friend to bore. If i had him bore my throttle body what is the most i should have it bored to?
    1994 Escort LX Wagon
    2013 Hyundai Veloster Turbo
    91 EGT - Junked May 2012
    I believe its 7mm over stock is the max. your friend is best to measure the port opening on the intake manifold and then measure the lower inside lip...since that will be the first section to run out of material the quickest.
      If it turns out good, I send you TB and some cash?
      -Dennis
      95 Nissan Pathfinder 4x4 - 191k miles
      I'll be back in the BG game eventually!
        ok cool. thanks. i was thinking of going 5mm larger at most. but idk thanks for this bit of info
          no problem, but you know the lower inside lip i'm talking about tho right? that'll be the first spot to run out of room.
            yea i look at the inside earlier and noticed that
              so when will you hear back from your friend? i'm sure if he's able to do this, a few ppl might want in on this. Probably doesn't cost a lot either.
                well he wont start machining classes until january. but its an idea i have floating around in my head.
                  meh i'm still running a stock TB haha
                    lol next you'll need a custom intake manifold jon
