ok so im having my stock flywheel machined by a buddy in classes. he was telling me about different finishes and we were both confused about what type of finish should be put on a flywheel. i told him that i think it just needs to be as smooth as possible. but i want some clarification. anyone who knows how to machine, what type or equipment should he use and what type of finish?
flywheel machining
flywheel machining
1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
"I usually downshift when I'm near a Prius so they can hear me hurting the environment"Tags: None
Wet stone finish... smooth and straight, and machined to the right step or cup. At the machine shop we used a diamond impregnated stone and coolant.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
Originally posted by Shades View PostWet stone finish... smooth and straight, and machined to the right step or cup. At the machine shop we used a diamond impregnated stone and coolant.
Originally posted by Henchman View PostHave some weight cut off it, I had my flywheel shaved down to 14lbs.1994 Escort LX Wagon
Yep: http://www.wihandyman.com/forum/show...3&postcount=13
But it was roughly 15lbs. I've driven an 9lb flywheel in a BH and that **** was so frustrating to drive on the street.1997 Protegé ES: The Power of BP
Broke Status FTW!
how much material did you take off the back? did you take much off the clutch side?1994 Escort LX Wagon
Originally posted by MATT91GT View Postok i will give him this information. what do you mean by the right step or cup?
I'm tired, so I don't know if that made sense.
Member of MX-3.com
would he have to do that in 2 places? where the flywheel bolts to the crank, and then the bolt holes for the pressure plate as well?1994 Escort LX Wagon
Originally posted by MATT91GT View Postwould he have to do that in 2 places? where the flywheel bolts to the crank, and then the bolt holes for the pressure plate as well?
Ok take a look at this picture... this is called a cupped flywheel, there is the other one called a stepped flywheel. So the clutch face was machined, yes. Also look at where the dowel pin is, the posts on the outer edge where the clutch bolts up to. That was also machined cause if you machine the clutch face then the cup gets deeper... soooo, you want to machine the outer posts back down to the specifications. Correct me if I'm wrong and if my memory serves me correctly this one is .787". It's been a long time since I've machined any. Pull the pin out first before you do... lol. You also don't want to leave a lip on the outer edge of the clutch face against the posts... hug that grinding stone right in there.
Member of MX-3.com
.787" is correctEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
ok thank you. i will forward this info to my friend who is machining it for me1994 Escort LX Wagon
Member of MX-3.com
