well I bought the tool too compress the valve spring with the head still on the block.I got four of them changed and was working on the fith one when I was putting the little metal clips on to hold he valve sping on the valve (which by the way for some reason seems to be a bitch) one of them wasn't in all the way and I released the pressure from the spring it then popped out and went in a hole in the head which i'm think makes oil go to the bottom end I gotta change oil pans anyway so am I correct on thiscause I stuck a magnet in the hole as far as the magnet was long and there seemed to be no end to the hole...i'm hopin the metal retianer is in the oil pan
Changing valve seals
Valve spring retainers are fun to put back in, aren't they? God, how I loathe them. Anyway, definitely check your oil pan for the rouge retainer. Drain the pan first (should be obvious, but just in case), if possible get an oil container with mesh of some sort over the hole, or put up some yourself (use a fine mesh, as the retainer is quite small). If you don't catch it there, check the pan thoroughly when you drop it. If you still don't see it, I'd check the oil you drained again just to make sure, then you're probably going to have to pull the head. That, or take your chances and start the car with the retainer in an unknown location. Do this at your own risk. I do not recommend this; I am merely stating your options. Maybe nothing will happen, but I wouldn't bet on it. Metal doesn't compress very well, and a piece of metal bouncing on top of a piston does bad things to your combustion chamber.1995 626: daily beater, mostly stock. Future NASA racer?
Next up: Speed6 or RX-8
damn that sucksyou should take a pic of where it fell, i think there's a oil flow diagram in the FSM that'll show if it has flow and where it may go...
Well guys I took the oil pan off and the retainer was in there gave the oil pan a quick shake and it fell right out....I finished all of the valve seals and installed the bp26 cams today which wasn't to bad (when your sober) the retainers are still a bitch but just gotta find your grove....hope I never have to do it again lol....so keep this in mind people if your gonna change valve seals don't drink a 12 pack of beer before hand.....Last edited by Zexcort; 05-02-2010, 04:57 PM.
1994 Escort GT Turbo
Where's the fun if you don't?? Lol1993 Protege LX-Midnight's shadow SOLD
sorry to drag up an old thread but whats a good tool to use to remove them. Ive been searching around but I don't want to spend anymore then 30$
The head is alredy off
Any luck with the c clamps? http://www.ebay.com/itm/8-Inch-Valve...e103aa&vxp=mtr
I heard these were **** http://www.ebay.com/itm/Universal-Au...d4b53c&vxp=mtr
And what about the lever style: http://www.ebay.com/itm/KD-912-Valve...a43e13&vxp=mtr
I tried this method http://www.youtube.com/watch?v=es6raocApZQ, but the springs are say to hard to push down. I might go to my shop and machine something up to get more leverage to push them down.
Thank for any info you guys have to offer.
1994 lx turbo in the works
1991 lx gtx swap---> sold
1992 lx turbo ---> deceased/rebuilt/deceased
1992 Ford escort gt ----> sold
Lisle valve tool #3620092 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
