hi everyone, i have a 92 mazda protege lx im trying to do a auto to manual tranny swap i have the tranny (g-series)but i also need to know what else i need to acomplish this so please give any advice or pics !
please help , auto to manual transmission swap
5spd transmission/accompanying mounts
the following mush also match the transmission:- clutch
- pressure plate
- flywheel
- axles
- half shaft
pedal assembly
clutch master cylinder
slave cylinder
clutch line (get the braided SS line)
shift linkage
short shifter (get bronze oil bushings while doing it)
dont forget to bypass the neutral safety switch, otherwise it wont start. I am sure I forgot something... good luck with the swap. There is plenty of info here on the board.
