well this morning i bought some Mass Air Flow sensor cleaner and unplugged the sensor and then i took off the 2 screws holding the sensor in. I was thinkin i could just pull the sensor out but when i took it part way out i saw the wire leads and tried to put it back in and it wouldn't go right back in so i kept tryin to bend the metal leads so it would go back in.. I didn't see anythin break off but i finally got it to where i could screw the sensor back into the housing. I plugged it back in and tried starting the car and now it won't start.. So now i'm thinking i might need a new MAF sensor cuz its not starting.. I unplugged the sensor again and it did start but the check engine light came on of course cuz the MAF was unplugged. Its a 1993 protege with the 1.8l DOHC . Don't know wat to do other than get a new MAF.. Any ideas?
Ok i think i messed somethin up!!!
2 screws holding the sensor in? this does not sound like the mass air flow sensor to me....are you able to take pictures to help? thanks-Jack
Originally posted by tonez79 View PostSo now i'm thinking i might need a new MAF sensor cuz its not starting.. I unplugged the sensor again and it did start but the check engine light came on of course cuz the MAF was unplugged. Its a 1993 protege with the 1.8l DOHC . Don't know wat to do other than get a new MAF.. Any ideas?
This is a MAF
Our cars use a Vane Air Flow Sensor.
This is a VAF
The VAF physically measures the air by how much the vane door is moved, the angle is measured via a carbon track potentiometer like a Throttle Position Sensor.
If you 'cleaned' the track with MAF cleaner, you most likely damaged the carbon tracking and it no longer has the correct resistance values.
There is nothing to clean on a VAF. It either works or doesn't.
MAF cleaners are designed to remove contaminants from the hot wire of the MAF. If that hot wire has a built up coating of oil/grime it will not measure correctly.
The only two screws I can think of that you removed are these...
-Michael
'90 Protege SE
Originally posted by charlesIt's probably to fix that ****ing automatic seatbelt
