Before you ask question about ex/intake cams swap please read http://www.wihandyman.com/forum/show...take-questions and http://www.wihandyman.com/forum/show...R-cams.-(BP26) for more informations.
I recently reground a set of 2 exhaust BP06 cams for my project http://www.wihandyman.com/forum/show...l=1#post719261
The goal now is to install the cams, by having stock BP26 turbo overlap of 10 degrees. From there, I'll tune it with the adjustable cam gears.
THIS POST HAS BEEN MODIFIED, AS I CHANGED THE MATH FOR A BETTER MATCH
What we have to know, from Mazda's technical data:
The stock BPT cams specs:
-intake open BTDC 2, close ABDC 51 = 233 degrees
-exhaust open BBDC 59, close ATDC 8= 247 degrees
-total overlap of 10 degrees
Stock BP 05 engine cams specs:
-intake open BTDC 5, close ABDC 48= 233 degrees
-exhaust open BBDC 56, close ATDC 14= 250 degrees
-total overlap of 19 degrees
The 274 cams from Colt Cams add 24 degrees from a stock BP05 cams, open 12 earlier and close 12 later. **Geoff from Colt cams told me that the cams centerline didn't move.**
I was about to pull out the engine, lol, to install the degree wheel, cause I couldn't figure out exactly the re-grind into the intake side, till I went deeper in this post http://www.wihandyman.com/forum/show...l=1#post678095 after I've been able to do the math and find a place to start with.
Remember:
turn the cam clockwise --> to advance
turn the cam counterclockwise <-- to retard
Basically, to install the exhaust 274 cam to this spec: open 86 BBDC - 8 ATDC, you need to retard <-- 1 tooth + retard <-- 2 degrees @ cam gear.
Intake spec: 2 BTDC - 92 ABDC, place the BP05 exhaust cam notch in the "I" mark, find the opposite tooth of the timing mark, advance --> 2 teeth + retard <-- 8 degrees @ cam gear and that's the mark you have to put to the top.
I'll take picture and post later...
**THOSE CALCULATION ARE BASED FROM A COLT CAMS RE-GRIND FROM 2 BP05 EXHAUST CAMS ONLY**
Remember:
