Hi Peeps.
I am encountering a weird problem on my BPT.
It runs smooth at 1-3K rpm.
But surge/hiccups starting at 3K rpm onwards.
I replaced the following to isolate:
-ignition coil
-HTW
-spark plugs
-stock fuel pump to walbro
-fuel regulator
-fuel filter
I also cleaned:
-distributor
What else should I check?
I can here a continuous "tik-tik-tik" sound on one of the injectors.
I can actually feel it when I hold the socket.
Any recommendations?
-ignition coil
-HTW
-spark plugs
-fuel regulator
-fuel filter
I also cleaned:
-distributor
