So I bought another Protege, 1993. DOHC gold LX automatic with cca. 95 000 miles on the clock. Needs a little bit of work on the outside, but interior is as new. The thing is that i don't see cruise control drum in the engine bay. Does automatic have CC on ECU so there is no need for a drum?
Cruise control on BP automatic
Crurise is vacuum operated. If all other components are present, the drum is just missing for some reason. If you only have the steering wheel switches I'd suspect a replacement steering wheel, as cruise was always optional.1990 Protege 4WD
1 3 5
2 4 R
No, the crouise control is there, it's fully equiped car, sunroof, ac, cruise, all electric..., former owner must have remove the acutator because he needed the space for LPG vaporiser. OK if that is that i'm gonna transfer the acutator from the other car. wich im gonna leave for spares. I'll drive this one with automatic gearbox and if i dont like it i'll swap the manual in it. Here is the pic of the engine bay.
Is it set up to run LPG?1990 Protege 4WD
1 3 5
2 4 R
Cool. If you make a worklog for that I'll follow it.1990 Protege 4WD
1 3 5
2 4 R
Oh that's too bad. Still, pictures of the result will be interesting to see.1990 Protege 4WD
1 3 5
2 4 R
1990 Protege 4WD
1 3 5
2 4 R
