There are two fans on radiator? I only knew of the one main one? Is the fuse you are talking about in that black box behind the air filter?
AC has no power
silly question... but do you have the blower fan in any of the "ON" 1-4 settings when pressing the AC button?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Yes, two fans. There is a large pull fan mounted behind the radiator on the port side for cooling the engine, and a smaller push fan mounted on the front to starboard for extra airflow when the AC is on.
And yes, the fuse I'm talking about is in the black box with relays and large fuses. It is a regular small yellow fuse labeled AD FAN.1990 Protege 4WD
1 3 5
2 4 R
I will have to look for that fuse tomorrow. I did not realize there was a second fan. We did have problems several months ago in that little black box blowing out the main 80 amp breaker with a huge radio amp that has since been removed from the car. My son drives the car at college. I will try and find the second fan tomorrow.
Thanks
Port is left and starboard is right?
QUOTE=me109;802025]Yes, two fans. There is a large pull fan mounted behind the radiator on the port side for cooling the engine, and a smaller push fan mounted on the front to starboard for extra airflow when the AC is on.
And yes, the fuse I'm talking about is in the black box with relays and large fuses. It is a regular small yellow fuse labeled AD FAN.[/QUOTE]
Originally posted by the5tolls View PostPort is left and starboard is right?1990 Protege 4WD
1 3 5
2 4 R
Yup. Ran my ac fan today. On the passenger side behind the grille91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by the5tolls View PostAC fan is not spinning but fuse is good?
Might check the contacts, make sure it's plugged in, or connect it to the battery and see if it runs.Last edited by me109; 07-14-2014, 06:21 PM.1990 Protege 4WD
1 3 5
2 4 R
a/c fans are known to seize up if they don't get used. remove the fan and turn it by hand. bet it will feel all binded up when you turn. if so keep turning it until it starts to feel better. then plug it back in and hope for the best91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
