Ignition Systems??
    Ignition Systems??
    Who has an aftermarket ignition system? What do you have and what are your thoughs? Im looking into some, just looking for opinions.
    Eat ****.
    i know nology has a coil and a booster and then wires its all in jcw or summit i cant remeber but i havent seen anyone with that and also ppl are using msd stuff too
    i is dumb
      i am curently running with the msd blaster SS coil and the msd 6A ignition box....i picked them up on ebay about 7months for only like 150 shipped.....new they can run you over 200 depending on where you buy them......but trust me they are WELL WORTH THE $$....i have almost no acceleration lag and i gained a very satisifying amount of hp
      91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
      More Information
        How did you hook it all up
        94 Protege LX: HX-35, Megasquit, ect...
        98 Subaru Legacy GT-DD: 1 inch lift, and all the standard N/A stuff.
          I have the msd blaster coil ,sci ignition and nology hot wires.Its a over kill but I'm a firm believer in never having too much ignition.
          1996 Escort GT
          2005 stg3 srt4 450hp 508tq 29psi
          1986 Mustang cpe 408 stroker
            the coil iss a direct swap and the ignition box comes with instructions.....just a wire to the coil and a wire to the battery.....
            More Information
              i have a 8.5mm magnecore wire for $80 and msd for $50. I'd like to say good stuff about it but i dont have any except for it looks good. And it gives me a hard time to read the timing which i would say is good for resistance but back for the mechanic. Maybe it works maybe it dont i really cant tell u cuz my car dont feel like it made any difference neither did the lx fuel pump and the ground wire kit.
                The only way real to tell if you gained anything small is to go to the dyno.I know this because I was goofing around on the dyno one day testing different octane fuels.I found out that going from 87 oct to 93 oct cost me 2 hp. Dont believe it neither did I. But the only changes to the car was the fuel in it.
                1996 Escort GT
                  hmm...i saw u have rx-7 vaf u must have a bp motor. Just curious wut gude head package did u get and how much $$ is it? and how much gain did u get. can u give me more info thx..........pm me.
                    the gude head package is about 1300 dollars. It is supposed to give you about 20 hp.. I saw this on someone elses car on the escort board if I am not mistaken. They dynod it.
                    I really can't remeber, it was so frigin long ago.,like last week ..
                    go to www.escortracing.com and look it up.
                    Bruce
                    photo album|photo album 2 (pbase)
                    dbest1a AT yahoo DOT com
                      The gude package consists of Ported head ,throttle body,both cams,ported intake.I gained 20 hp to the wheels. Its pricey costs about 1400.00
                      1996 Escort GT
                        see if you go to a ignition system you will have to upgrade a few things. i just bought a msd system with coil and boost retard. if you buy an MSD modual you will need to upgrade your stock coil. your stock coil is now seeing a stronger more percise signal which it was not designed for.
                        it will take it but people will start putting money on how soon it goes. it is like puting 220V through a socet designed to take 110V sure initial it will take it but it wont last long.
                        When you turn your car on... does it return the favor?
                        Originally posted by goldstar
                        Yes, still have it. It was my attempt to immortalize you in verse.
                        A Protege driver named Brock
                        So his engine he goosed
                        With much too much boost,
