For all who where wondering you can use the stock gtx flywheel and clutch with the front wheel drive transmission. I`m using one i had in spare and it holds great even if i didn`t even had it rebuild.
gtx clutch and flywheel
the 230mm GTR clutch plate will fit on a G series tranny too, but if you go that way look into a stage 2 or 3 pressure plate from Bully or ACT.When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
The flywheels aren't the same so you should not be able to but a performance clutch for a fwd, that's my guess. I didn't even had the gtx clutch rebuild i just put it in to get the car moving while waiting for my automatic to be fully build but from what i tried it holds really good and i'm not running the engine stockhttp://www.cardomain.com/id/protila
Transmission mechanic
