Don't waste your money with that custom intake stuff. Your intake tubing flows more than enough air for the power your car is making. You could have 9" piping, and it won't make a whack of diffrence since the stock AFM is a bottleneck. I've dynoed the stock intake with a K&N, Fram, and with no filter, and they all made the same power. Which means the restriction is at or after the AFM.
You have a SOHC or DOHC? If you have the SOHC, don't waste your money on any kind of intake system. If anything, just get an adaptor and pod filter. If you have DOHC, get the RX7 AFM with the adaptor and pod filter. I got 3.5hp over the ENTIRE rev range and 5hp at 7000rpm. It's a myth that it only gets power above 6000rpm. That was just one guy's experience. The key is dyno tuning it. Adjust the spring tension while on the dyno. One click made a 4hp difference on my car.
