Local Alt. shop down here says they can do it , but a rewound Alt. wont last as long as say a stock Alt. They produce to much heat which kills them quicker. That is one of the reasons I would like to run a stock 140 amp GM ice alt.
alternator upgrade
c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
guys does anyone have a functioning link for the V6 alternator swap onto a BP motor / harness? Was hoping to do this ASAP but I cant find any working links!
edit/found it.
gotta go find a mpv alternator bolt somehow now..anyone know the length / thread of the bolt? Maybe I can get one at a hardware store?Last edited by vtec-this; 04-09-2013, 08:32 AM.
S197 Mustang GT Convertible The New DD. (Ford Racing 3.73/JLT CAI/SCT SF3 Tuner/Ford Racing Exhaust)
2009 Nissan Rogue SL AWD Maximus Tractionous Wifeymobilious
Previous ~ 235whp 1.8 BP Powered 2003 MazdaSpeed Protege ~ - Sold
shouldn't be an issue using the KL lower alt bolt. just grab the whole shebang.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
yep, pretty sure the Alternator has the threads cut on the one side anyways, while the bracket is just a slit to pivot the lower bolt on.-Jack
i just went to mazda today and ordered the proper mpv bolt. cost $4 told em 96 mpv v6 it should be here tomorrow.
Search provided this oldie but goodie, sadly the links don't work. I pulled my alternator yesterday, having waited for an outside temperature of 104 degrees, and found the original 24 year old Mitsubishi unit. 65 amps. Isn't anything built to last?
Does the mx-3 v-6 bolt right in and hook right up?
Could the clips on the molded plug be any harder to compress and pull out?
I'm hoping to get this done this afternoon since it is the last day of 104 weather for a while...
Thank you.1990 Mazda Protege LX, owned since new
I just had an optima fail at 6months so you should be happy you got 6 years, they don't make them like they use to.
If going wet cell I still fully recommend auto-zone diehards, I got a decade out of one and it didn't die it just had a terminal crack.
For AGM I'd go either interstate or Odyssey in the current market.Beater=/= Sleeper
any of the V6 KL's really. year isn't particularly important---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
