Anyone know where I can find some stronger axles? I've gone through 2 sets in the past 3 days and at this point am willing to spend more money for a stronger pair instead of changing axles every day.
Axle Question
Axle Question
1991 Mazda 323 GTR Sedan
MODS:
GTR motor swap, F&R Familia strut bars, MX-3 Rear Lower strut tie bar, GTX front bumper, GTX grill, EDM headlights & corners, EDM 323 rear garnish, EDM spoiler, EGT sideskirts, MX-3 seats, GTX steering wheel, EGT glass sunroof, WRX hood scoop (functional!!), and other things that take too much space to list.....
TO DO LIST:
EDM/JDM rear bumper
EDM/JDM power folding mirrors
Repaint carTags: None
The intermediate shaft isn't the only part going. Apparently, the axles I get don't like boost because I get 1 good pull and then on the 2nd pull everything goes to ****. As far as the wheel hop, I have none, however on the top end of 2nd-5th, I have wheel spin after I hit boost.1991 Mazda 323 GTR Sedan
MODS:
TO DO LIST:
EDM/JDM rear bumper
Repaint car
Are you using OEM Mazda pieces or the cheap Autozone remanufactured axles?-------------------------
'91 LX
'03 Mazdaspeed Protege #235
I've tried both, and they both end up the same way....damaged.1991 Mazda 323 GTR Sedan
MODS:
TO DO LIST:
EDM/JDM rear bumper
Repaint car
the only thing i have found out there is this....
not sure if it will work or not with our tranny
level 2 300hp axels
hope this helps---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
A good find, although a bit pricey at $700 for the set.-------------------------
'91 LX
