my mom was driving my '93 323 and she crashed into the back of a truck, it totally screwed the hook up, is there any other car hoods that fit my 323, like meybe a protege or a escort...well if u have info on a new hood let me know plz...!
323 hood screwed
you could use the 94 protege hood it is the same i thinksigpic gtx swap,pacesetter cat back exhaust,civic short shifter,both front and rear upper strut tower bars,high flow cat,,mx-3 lower tie bar,mx-3 front seats,zxtuner poly motor mount inserts,manual seat belt conversion,mx-3 lether shift boot,
come to mazdasnw.com if you live in the northwest
I have tried this and know first hand. The only hood that fits the 323 is a 323 hood. The only way another hood will fit is if the fenders are swapped out as well. Even then I am not 100% sure if the hinges will even line up.
The 94 pro hood has the same slanted headlight design as the 323, but is still physically 2-3 inches wider. Try local j/y's. I had a biatch of a time finding a hood for my 323. For some reason almost all of the 323's in my area have some sort of front end damage.
I think u can put on a protege hood, but you just wont have the dip in the middle and I believe the 94 protege hoods have the dip to clear things up.James G.
sobe83@yahoo.com
AIM: DVS 323BPT
MySpace
Cardomain
<BR>
<marquee>Turbonetics T3/T4, RC 550cc injectors, Walbro fuel pump, SSAutochrome Miata manifold, Tial 35mm wastegate, large FMIC, Apex-I SAFC, GReddy Type S BOV, 2.5" aluminum charge pipes, NGK plugs/wires, RX-7 VAM, 3" turbo-back exhaust, ARP head studs, H&R Springs, S/R struts, Sony XPlod deck-2/12" subs, Power Acoustic 800w amp, Pioneer speakers, Evo front bumper, ADR DV8 17" wheels.</marquee>
