I got rid of my passive seatbelts a couple months ago and that of course leaves behind the console with the slots in it. I saw a sticky thread by Gro Harlem that says the Protegé can use an MX-3 console so I've been trying to get a 94 or 95 rear console. The screws at the back of the old console went into a metal plate attached to the assembly for the shoulderbelt reels that are no longer there. Can somebody who is using an MX-3 console in a 1st gen please tell me how you screwed it down at the back? I would try and figure this out myself but MX-3s never show up at junk yards around here so I have the buy one online and I need to know if I should ask them to include some sort of bracket with the console. Thanks.
MX-3 console, how does it mount at the back?
You need to get a "special" bracket by special i mean canadian... :DWhen you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
Originally posted by WombatThanks, I'll put that on my shopping list for the next time I head north.'91 Mazda Protege GT/ Completely re-built engine w/.020 head shave, intake/exhaust P&P & 3 angle valve job, 2.25 full custom exhaust, RX-7 AFM, K&N Cone, 18* Timing advance, exhintake cam mod w/Fly'n Miata adjustables, Custom short shifter, CenterForce clutch, lightened flywheel, HAWK pads on all 4, Motegi Racing 8 spoke 16"s w/205/45/ZR16 rubber, VentShade window visors, lower lip spoiler, 4" driving lights w/halo's. MX-3 center console & Black carpet swap w/2 layers dynomat type insulation.
Soon to come... Garret T25 turbo, DSM injectors, GTX ecu (Needed) SAFC (Needed) FMIC (Needed)
'91 Toyota Soarer GT-TL/ Stock 1JZ-GTE, K&N drop in filter, Gewalt Evolution deep dish 17"s, Nardi steering wheel
Do not be conformed to this world, but be transformed by the renewing of your mind!
Originally posted by CBlazeI was thinkin on maybe going over to midnight autoparts tomorow, I also have a few things on my list. I can take a look for your bracket and console, ther are 3 or 4 MX-3 GS' in my local yardJust let me know how much they're charging and I'll send you money. If they've got a tan console then my interior will still match, but I realize that black is the common color for the MX-3. Even if you can only get the bracket that would be great because I found a couple of people online parting out 94 MX-3s with good consoles.
If you get over to the junk yard tomorrow let me know what you find. Thanks!
i had to go back to the farking yard to get the bracket that was on the 95' MX3 i ripped the console out of....
Its just a peice of metal bracetry that bolts where the seatbelt reels used to...it lets you screw the two crews in the side & also raises the console from completely touching the carpet.
Also make sure to get the lower anchor brackets for the lower bolt for both sides of the seatbelt. It is located essentially where the lapbelt reels were installed on the auto-seatbelt models.
You can, if you want, just bolt them to a hole on the floorpan, but using the brackets ensures the proper angle/placement of the lower anchor.93' Noble Green MX-ZE (sold)
